-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Manifold Pressure Control Sensor (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/329578-manifold-pressure-control-sensor.html)
Corporal Beef 02-09-2007 03:22 PM
I'm having intermittent problems accelerating, and I've been told the problem is my MPC sensor. Is this a common problem?
Bleyseng 02-09-2007 07:05 PM
Bucking? thats usually the TPS on the throttle body so try unplugging it to see if it clears up.
The MPS controls the AFR via manifold vacuum, so if you have tons of vacuum leaks due to old hoses, seals etc the AFR can be off.
The vacuum advance plate inside the dizzy could be sticking too.
Corporal Beef 02-10-2007 05:52 AM
Bucking indeed, but only occasionally. Thanks for your advice; I'll check those things as well.
