Unhappy Ignition:Sparks for moment, then nothing
74 2.0
Daily driver that has run great for years then all of a sudden died. Now it occasionally starts runs strong for 30 seconds then dies completely.
Troubleshooting:
Battery fully charged/car cranks strong
Getting fuel, just no spark
ground strap cleaned
Neg Battery cable checked
all relays on board checked
When engine cranked, I get a big fat spark from the coil for a few revolutions then nothing
Points clean and operate normally, you can see them work with the cap removed, electricity flows for the same amount of time as the coil
Cap clean, not cracked
Rotor like new
Alternator and dashboard operate normally, light goes out when it decides to run.
Cleaned and reseated just about every electrical connection
any help greatly appreciated, Thanks
Old 02-22-2007, 08:10 AM
Check/clean the ground wire connections on the engine harness. Particularly the group of white ones under/behind the plenum - I forget exactly where they bolt up.
Old 02-22-2007, 08:18 AM
Rouser's Avatar
Send a message via ICQ to Rouser Send a message via AIM to Rouser
Try swapping coils ...
Rouser!
Old 02-22-2007, 11:43 AM
Unhappy
Tried swapping coils and cleaned/reattached white engine harness wires. no change.
Old 02-22-2007, 04:17 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
How's the ground braid inside the distributor?
--DD
Old 02-22-2007, 06:01 PM
Conrad W Peden's Avatar
Try with the Tach disconected.
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 02-22-2007, 09:59 PM
The culprit: ground braid solder point in the distributor.
Thanks to DD for the insight.
Old 02-24-2007, 12:09 PM
