speedemon666's Avatar
Front Suspension Loose
The torsion bar adjuster lever is loose. Does anybody know how this is attached? The manuals I have doesn't show how they are attached in the diagrams.
I also have a sound like a tire rub when I turn the steering wheel. The tires have plenty of clearance.
Old 02-27-2007, 05:18 AM
Is the adjuster loose when the car is sitting on all 4 wheels or when you lift that corner?
There is supposed to me a felt piece behind the adjuster up against the tube. Suppose to keep it from getting dirty. I've never seen one.
Are there marks on the tires? may have to take them off to see. If your suspension is soft and your car is too low the body will rub in hard corner when suspension compresses.
Old 02-27-2007, 07:35 AM
The adjuster is loose (wobbles by hand) when the car is up and tight when it's down. Pressure from the torsion is making it tight. I'm guessing it's held on by a circlip.
The noise can't be tire rub, I hear it while at a roll and while turning the steering wheel. There is no noise when cornering hard or at full lock.
The suspension is a 911 conversion with a welmeister bump steer, done over 6 years ago. The only recent work done to the front suspension was a new set of tires and a wheel alignment.
Old 02-27-2007, 07:40 PM
No cir-clip to keep adjuster on. However the splines on the torsion bar should be tight enough to firmly hold the adjuster on without any wobble. Mine need a slight tap with a hammer to get on. If you need a new one I probably got another extra.
Wheel bearings? or steering shaft is rubbing somewhere. you know there is a bearing on the body under the gas tank. Steering shaft u-joints getting loose?
Old 02-28-2007, 04:31 AM
Thanks for the help Joe.
Old 03-01-2007, 01:55 PM
Did you figure out what you need?
Old 03-01-2007, 02:31 PM
I just came in from the garage.
The steering coupling (Haynes, Fig. 7.12 item 25) is slightly binding, just enough to make some noise but no tension in the steering feel.
Wheel bearings sound/feel smooth.
I gave a tap on the adjuster with some wood and hammer but it's still loose.
For now I can live with it with the way it is. I'll tear into it when I rebuild the engine this year.
Old 03-01-2007, 05:06 PM
