914 1.7 4 carbs- spitting gas and exhaust from carb?
so I bought this 914 today that runs kind of ruff. I decided to take of all air-filters and cylinder number 3 is spitting up air and fuel.
What could be the problem? All the other carbs are fine and on occasion the car will backfire.
I tried using the search with no luck, Someone please help.
I am new to carburator cars. Sorry.
Old 03-11-2007, 10:27 AM
Brother's Avatar
have you done a valve job?
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 03-11-2007, 12:03 PM
valve job was done 1000 miles ago
Old 03-11-2007, 12:31 PM
Also noticed that the gasket between the downtube and the carburator is wet. and is only wet on this one cylinder.
Old 03-11-2007, 12:38 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Downtube == manifold? Or is it above the carb?
Spitting up air and fuel sounds a lot like a valve problem. Do a compression test and see if that cylinder has significantly worse numbers than the rest. If so, you've got some $$$ you're gonna have to spend.
Check for vacuum leaks, too. Carbs dislike 'em, not as much as L-jet does, but they definitely don't like 'em!!
--DD
Old 03-11-2007, 05:08 PM
the leak is in between the carb and the tube that goes into the engine (intake tube)
Old 03-11-2007, 05:54 PM
Brother's Avatar
An air leak there could cause backfires due to a lean condition. This is kind of like an air leak in a CIS system.
Paul
1972 914 - Sold
Old 03-11-2007, 06:05 PM
Administrator
That would be AKA the manifold. Definite leak there; definitely not good...
--DD
Old 03-11-2007, 06:54 PM
Brother's Avatar
make sure you are not smoking a cigarette when you are leaning over the engine bay.
Paul
1972 914 - Sold
Old 03-11-2007, 07:33 PM
Start my tighting all the carb and MANIFOLD mounting bolts and nuts.
Paul Woodbury
See my Rennport Reunion and old IMSA pictures here:
Old 03-12-2007, 03:45 AM
first. the intake studs require very little torque. the haynes calls for 4.35 lbs (don't know how correct that is) and the cb books wants 18. if you're using a cut washer under the nuts you're prob exceeding those #s. i use the same locking washers used on the cv joint bolts for the manifold studs and the carb to intake studs. tighten everything down in equal stepped increments.
a bit more info (what brand of carbs) and a couple of pictures will help us. you should buy the weber book published by CB performance and a syncronometer. you will need both.
k
here? not so much i think. high five!!!
Old 03-28-2007, 07:59 AM
Groucho Marxist
Tobra's Avatar
and have a fire extinguisher handy
"Keep your eye on one thing and one thing only: how much government is spending, because thatís the true tax ... If youíre not paying for it in the form of explicit taxes, youíre paying for it indirectly in the form of inflation or in the form of borrowing."
Milton Friedman
Old 03-28-2007, 03:31 PM
So why hasn't anyone just told him to clean the idle jets.
GEEZ I just went through this today with a red 914.
3 of 4 jets were partially plugged.
Ran like a champ after some CARB TLC.
Old 03-31-2007, 05:59 PM
