-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Injector Flow Rate (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3373-injector-flow-rate.html)
rjm 06-25-2001 07:56 PM
Injector Flow Rate
Does anybody know what the flow rate is for the "green" fuel injectors? Specifically the ones used in the '75-'76 2L
(Bosch # 0 280 150 038)
pbanders 06-26-2001 11:48 AM
No - I've never seen this figure published anywhere. The only figure I have for D-Jet cars is for the 1.7L injectors (0 280 160 009) at 265 cc/min (26.5 lb/hr).
Brad Anders
Roland Kunz 07-03-2001 03:27 AM
Hello
Those datas where puplished in several books.
I have the Kaesedorf Gemischbildung Vol IV.
The Injectors flow are as following:
Black: 265 ccm/minute
Yellow: 265 ccm/m
Blue: 318 ccm/m
Green: 380 ccm/m
Meesured at 2,0 bar 3 Volt and 0,15 mm +/- 0,05 mm lift.
Black and Yellow are identical in flow only VW used Yellow injectors. As far I remeber the Yellow ones had some internal upgrades.
Grüsse
pbanders 07-03-2001 08:08 AM
Wow, great information, Roland! Perhaps others have seen this data, but I haven't come across it. I'll add it to my D-Jet parts web page today.
http://members.rennlist.com/pbanders/djetparts.htm
Roland, you list only one "green" injector, which would be for the 2.0L. But there were two 2.0L injectors that were used, the 0 280 150 019 for the 1973 - 1974 models, and the 0 280 150 038 on the 1975 -1976 models. I had heard a rumor that the 038 injector had a higher flow rate than the 019 injector. Does your reference make any distinction between these two injectors?
thanks,
Brad Anders
[This message has been edited by pbanders (edited 07-03-2001).]
Roland Kunz 07-03-2001 04:37 PM
Hello
As far I remeber the ordernumber changed as Porsche used the same injectors like Mercedes.
Generally over the time the injectors get a improved coil and therfore can use a stronger valve seat coil with allows higher rev use, a better nozzle and a different internal mesh filter ( needed as the lead went down and alcahol got supstituded ), same reason is why the black changed to yellow.
The newer injectors can run on lower pressures and have several other benefits. They can be mixed/updatet with the old injectors. Avoid mixing generations or downmixing first gen on secound generation ECU ( With the CO screw outside and the other injector triggering ( buffered ?)).
You also can find injectors in Opel, BMW, Volvo, Jaguar and some Aston Martins.
Avoid using yellow D-jets on L jetronic or digifant injectors as they will kill the brain.
( L Jets have 16 Ohms versus 2,5 D Jet )
Grüsse
