Throttle cable bracket for dual Webers
Just got dual Webers (44 IDF's) for my '73 2.0. What can I use to bracket my throttle cable, and where is the best place to locate the bracket?
Old 04-03-2007, 06:00 AM
Your creativity will be your only limit.
I got ahold of some 1/8" steel plate cut and bent and drilled till I came up with something that did not flex forward or aft.
it sits inbetween the oil fill stand and uses the 10mm stud as a mount point and also a 13mm bolt on the case.
Tough to get pictures.
Been through several designs that all got bent after a few too many WOT excursions.
Old 04-03-2007, 11:56 AM
