bcheney's Avatar
914/6 conversion oil tank install
I have a OEM 914/6 Oil tank that I need to install into my conversion project. The car is a 75. Can anyone provide step by step instruction on how to install the tank? Just want to know the steps from someone who has completed this work so I can avoid mistakes. I have the 914/6 conversion guide from Auto Atlanta. However, it simply tells you to use the template they provide and install.
08 Cayenne V6
89 911 Targa Carrera 3.2
75 914-6 Conversion
Old 04-19-2007, 05:23 AM
Hell Belcho
Nostril Cheese's Avatar
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=914_USA_KATALOG&Illustration=104-00&Line_Item=7
this may help.
IIRC, you use rubber isolating grommets between the tank and the panel. You'll also need to cut some holes in the panel for the oil filler and filter. I think they are already embossed into the sheet metal.
Old 04-19-2007, 11:32 AM
thesey914's Avatar
I cut my holes a few weeks ago -hope this helps
Oil tank holes
Old 04-21-2007, 12:51 AM
bcheney's Avatar
Those pics are beautiful. Did mine yesterday. Thanks for the detail, thesey914. Will stay in touch through the conversion process. If you have links to any other work you done let me know.
Cheers!
Brian
08 Cayenne V6
75 914-6 Conversion
Old 04-23-2007, 03:54 AM
