-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   injector trouble (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3457-injector-trouble.html)
scotty914 07-13-2001 06:07 PM
injector trouble
well i have gotten a little farther on getting my car running again ( 75 1.8 )
i get a stream of gas out of the passenger side injectors, but nothing out of the drivers side, they do viberate but no real flow ( i do have gas on the drivers side ).
now for the story for those who did not read it before... i changed the gas tank but before hand i had major rusty tank, i think i have clogged my injectors with rust, can i get it out with out buying new injectors ( or used )
or could this be an electric problem ( both injectors on one side )
also i just ran compression on my motor it runs from 120 to 135, i think that is good ( new rings only and cold motor )
TIA
scott thacher
75 1.8 on the road again
75 under rust
(fine german rust)
bowlsby 07-13-2001 09:54 PM
Swap the injectors from side to side and see if the problem is the same.
