Consistently running too rich, even at 26psi on 1.7 D-jet
Getting my EFI system up to speed, but still running sooty (on the plugs) rich at all times. I have the set-screw on the ECU turned counter-clockwise all the way, & I'm running 26psi fuel pressure on stock injectors on a stock engine (1.7l D-jet). I don't want to try any leaner as I still want to ensure enough fuel on WOT: Plan to install my Wideband O2 this weekend so I can check things better.
I've gone through the entire EFI system: new hoses, clamps, checked sensors/valves, new vacuum lines, & recently, the following: *Timing is at the red tick mark @ 3500 w/both vaccum lines removed/plugged on the disty *Disty is rebuilt with good diaphrams in the canister *All vacuum lines are new good, vacuum is 14" at idle, quickly zero's when throttle is blipped *Intake boots are fresh, intake manifold gaskets are new *Fuel injector seals are new, EFI lines are new *Compression: 125, 127, 128, 130 on a stock 1.7l d-jet *TB recently replaced with a good used oned: bypass ports were/are clear, idle-set screw is all the way in, & does raise idle further if loosened. *TPS was set via ohm meter off the popular Pelican Parts forum reference *if Disty is retarded to get idle down to 1k, car will not rev, just bogs *balanced injectors (stock), & tried a few more as well to get even flow patterns (via reading plugs) Any ideas?? |
Does the MPS hold a vacuum?
yes, I should put a gauge on it, but I got it to hold about 17-18" for a while back a month or two ago.
I need to check the ECU & MPS part numbers, ensure they're not for a 2.0 d-jet. |
| All times are GMT -8. The time now is 11:33 PM. |
