How the heck...
...do you change/adjust the alternator belt on a 914-6 conversion?
I did a search, and it appears cutting an access panel between the seats is possible, but I'd rather not. :confused: |
drop the engine.:confused:
Cut the back oanel and make an access port. Aquire a piece of sheet 2" larger overall then the cut out and use aircraft fittings to make it easily removable.
>M< |
cut an access hole and make a panel to fit over it.
http://forums.pelicanparts.com/uploa...1183729589.jpg http://forums.pelicanparts.com/uploa...1183729623.jpg an aluminum panel fits over the hole. You can either use nut-rivits, or tack weld some nuts to the back side so you can bolt the cover in place. |
Nice solution, you could put a bead of silicone or some weatherstrip around periphery to seal it too, in case you drive in the rain
| All times are GMT -8. The time now is 07:00 AM. |
