-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Removing the speedometer (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/357101-removing-speedometer.html)
xiat 07-13-2007 05:09 PM
Ok...I've decided to look into the odometer problem. I have the speedometer loose in the dash hole but it wont come out. How do I get it unhooked from the cable that runs down to the trip reset knob.? Is that what's holding it in there???
Roger
'74 914-2.0
Dave at Pelican Parts 07-13-2007 06:56 PM
The reset cable is simply pressed into the back of the speedo; there is a plastic barb that gets wider after it pushes through the hole. You should just be able to pull it out, I think.
Or you could take the knob off the bottom, then remove the nut that holds the cable onto the underside of the dash.
--DD
