Turbo Tie Rods!
I am trying to replace my stock tie rods with the turbo tie rods. Unfortunately I can't get the inner eye bolt loose. Do you turn the eye bolt clockwise or counterclockwise? Are you suppossed to loosen the bellows holder first? If so how can you get a hold of it to loosen it???? I feel like I must be doing something wrong and that this shouldn't be hard. Any suggestions would be greatly appreciated!!
Alex
Old 08-05-2007, 02:46 PM
hank911's Avatar
Hold your breath and pull on the wrench ( counter clockwise ) until the veins pop on your head. I think I used a larger pipe wrench as I wasn't going to use the old tie-rods again. Good Luck!!
HankP
1976S Targa
BMW R100RT&RS&R75/5&6
Horizontally Apposed
Old 08-06-2007, 07:20 PM
