Poor-sche Lover's Avatar
Flywheel/Transmission Q's
Hey guys,
I am preparing to replace my rear main seal in my '74 2.0 L. I am planning on doing this while leaving the engine in.
1. Is there anything suprising I need to watch out for?
2. How terribly important is the flywheel crush washer and o-ring?
3. Do I have to buy a flywheel lock, or is there a more "ingenious" solution?
Thanks for all your help.
Old 08-04-2003, 05:28 PM
I read the tech article on clutch replacement when I did mine, also with just the tranny out. I believe they recommend the bolts and crush washer. Make sure the flywheel pilot bearing is there and in good shape. Mine was disintegrated, as were the felt and o-ring. I also replaced the tranny seal and the recommended clutch related parts. I made a flywheel lock out of a 1-1/2"long piece of u-channel with flat pieces (with clearance holes for the studs) welded to both ends.
If you don't have a welder maybe you could use a 1/8" thick piece of steel and bend into a U, then cut slots on both ends and bend them over and drill holes.
Ed
'74 914 V8
'70 914
Old 08-05-2003, 09:21 AM
dc914guy's Avatar
Send a message via AIM to dc914guy
Everyone I talk to says to replace the flywheel bolts and crush washer.. I am preparing to do a complete (flywheel / pressure plate / clutch) job this winter.
Eric Devansky
986s - Radio Flyer
20% of a 951 parts car remains
Old 08-05-2003, 11:24 AM
Morrie's Avatar
How important is the felt?
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 08-17-2007, 10:50 AM
