whitemike_04's Avatar
Question Is it a 2.0?
How can i tell if my '73 914 is a 2 liter or 1.7? It does not have an engine, or emblems. But it does have the swaybars and center console but doesn't have stock rims. Is there a way to tell by the VIN number?
Old 08-04-2001, 12:24 PM
Jim Smolka's Avatar
Post
If you still have FI, check the number of nuts that hold the intake to the head. If there are 3 than 2.0. If 4, then a 1.7
Not sure of the VIN IDs
Old 08-04-2001, 06:28 PM
Post
i dont hab any engine components
Old 08-04-2001, 11:57 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
Look for factory sway bar mounts under the front fenders, you will see three holes and one larger hole.If these are there then it is more than likely a 2.0. Do you have the fuel pump or any of the FI componets? check the parts #'s as 1.7 and 2.0 use different parts. what is the VIN. Try PNA for a Cardex that will tell you for sure. Steve
Old 08-05-2001, 08:01 AM
mejulihn's Avatar
Post
I assume you mean whether or not it originally had a 2.0 -- with no engine in it, does it really matter? I do not know if any 1.7's came with appearance group options or not, but as Steve mentioned a cardex from PCNA ($30 plus a wait) will tell you about original equipment on your car.
Old 08-05-2001, 08:33 PM
