-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   What brake line to use for 320i front calipers? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/362538-what-brake-line-use-320i-front-calipers.html)
Roy Josef 08-18-2007 12:53 AM
It seems the time has come to replace all the seized calipers on my '73 2.0. I am considering doing the 320i front caliper 'upgrade' which some here seem to love. I would like to have all the parts ready to go so as to have minimal downtime. After reading the tech article and many posts on the subject I am unclear as to what front brake lines to use to make this work or if it is possible to modify the stock 914 (or 320i) lines? If not can I buy the correct lines ready made? If they are not available can someone provide the specs I would need to make them such as length, diameter, flare type and fitting type? Thanks for any help!
Roy Josef 08-18-2007 07:01 PM
With more than 250 views and no responses I must be doing something wrong. Please forgive my newbiness, can someone enlighten me!?
914GT 08-18-2007 09:42 PM
I believe I modified the stock brake lines for the 320i calipers. There will be folks who will say never to do this, but I recall having no problems when I did it about four years ago. The tubing showed no signs of fatigue or stress cracking otherwise I wouldn't have used them. You shouldn't have to bend the lines excessively to the point the tubing is weakened.
Joe Ricard 08-19-2007 07:54 AM
I went to FLAPS and bought a new short brake ine and bent it as needed.
I felt that the stock one a a bit too short.
This was on my 1st 914.
My current car has stock early fronts
