low grumbly sound while driving
On my way home with the 76... (the first 914 I've driven with the Porsche engine in it) It was making a low grumbly sound while I was driving at speed. At first I thought it was the engine... But then I went through a nice twisty canyon, and while going around curves to the left, the car was very quiet and a nice ride, but on the straight-a-ways and right hand curves, it was quite annoying and loud.
How do I tell if it is the front wheel bearing, or the rear one? (or is it possible that it is something else?)
- Jim
Old 09-09-2007, 08:01 PM
Max2.0's Avatar
Maybe a CV Joint? Does it sound more like coming from the front or the rear? Could be a bearing... or a loose Brake Caliper?
1983 911SC... Concours Garage Queen
1987 Carrera M491 Cab... Movin' on out...
1992 968 Coupe Track Car... Gone
1968 911L, '73.5 911T, '75 911S SA, '77 911S Targa, and so forth, thru a '90 S2 Cab...
Old 09-10-2007, 06:40 AM
That could be it right there... the brakes. He (the PO) told me that he had just got the brakes done. I'll check that before I go digging into that rear wheel bearing. Thank you for pointing out the simple solutions first!
- Jim
Old 09-10-2007, 07:23 AM
I jacked the car up this morning/afternoon (I jacked it up twice for clutch adjustments) and decided that it is indeed the left rear wheel bearing! THank you Max for the reply.
- Jim
Old 09-10-2007, 02:43 PM
