-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Engine specs (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3666-engine-specs.html)
whitemike_04 08-09-2001 10:47 PM
Engine specs
yo, anyone know how to inexpensivly modify a 74 1.8 engine to be faster than a 73/74 2.0?
Jake Raby 08-09-2001 11:31 PM
A set of 96mm pistons, 86A web cam, nice pair of heads, and bump the CR to 8.5:1
This should do the trick, quite well.
Jake Raby
Raby's Aircooled Technology
www.aircooledtechnology.com
Bleyseng 08-10-2001 07:54 AM
A nice turbo would do the trick! It's been done to a 1.7l with CIS FI too. Not sure how much hp he is getting, maybe he will post his results. Ed?
Geoff
http://www.pelicanparts.com/support/.../hotbounce.gif
oredith 08-10-2001 02:00 PM
a "baseline" turbo will run anywhere between 500-1000 bucks.. depending on how resourceful you are..
you'd have to be able to weld, and have your own welder though..
Jeff - 2.0L turbo..
