-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Ignition Questions (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3669-ignition-questions.html)
TomInVegas 08-11-2001 10:11 AM
Ignition Questions
I have a '74 2.0L with dual 40 IDF's that I just added a Bosch 050 dizzy to with the Compufire point eliminator and wanted to know what I should set my plug gap to. I've got W8cc's and a Bosch Blue coil. I was told that the blue coil put out around 30-34k volts so I should be able to use a larger plug gap with the Compufire. I'v got them set at .035 now and it seems to work pretty well. Any input appreciated. http://www.pelicanparts.com/support/smileys/wat6.gif
