shims needed when using 911 sport mounts for 914 trans mounts?
Hello All,
I have a pair of 911 sport mounts mounted on the 914. I just came across what I think are the original trans mounts for a 914. I did not have an opportunity
to measure, but the originals definitely looked thicker than the sport mounts.
Are the originals thicker and if so, should I place shims somewhere to make up the difference? This would lower the end of the trans and slightly change the angle that the engine/trans assembly sits in the body back to original.
It would not be much, but I was thinking about the effect of a slightly raised trans would have on the shift rod as it enters the transmission.
Am I worrying about nothing?
Curt
Old 10-02-2007, 12:15 PM
King Broinyo
Nostril Cheese's Avatar
side shift or tail shift?
do the mounts already have that big ass washer between the tranny ears and the mount?
Old 10-02-2007, 02:37 PM
Oh yeah, right, forgot to mention that this is a 73 914 with side shift.
And yup, there are some big upside down saucer shaped washers in there.
Curt
Old 10-02-2007, 03:03 PM
