Blew my fuel pump fuse!
When I had started up my car yesterday the voltmeter was pointing to the far right and when I revved the engine the needle would go further to the right. I started driving and after about 5 minutes I blew my fuel pump fuse I replaced that but it blew again, tried about 3 times. The fuse goes after about a second or two of the fuel pump runnning when I turn the ignition key. The car is a 73 and I had done to fuel pump relocation a few months back and havent had any trouble with it until now. I have the car parked in a bad place any help from anyone so I could get this car moving would be appreciated, thanks. One more thing, I dont hear the fuel injectors clicking anymore when I press the throttle down, anyone know how much trouble I'm in? The ground strap from the transmission and for the injectors are connected.
[This message has been edited by Steve M.]
Old 11-15-1998, 04:30 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Could be as simple as a bad voltage regulator. Could be a lot worse.
Tow the car either to a shop, or to somewhere you can work on it. Use a good voltmeter to measure the voltage across the battery terminals. Don't trust the gauge in the console, they often give incorrect readings.
Hmm--a thought! The new wiring could have abraded away against something, and now be shorting to ground. That's the best guess off the top of my head.
--DD
Old 11-16-1998, 09:43 AM
