Help!! Type one Prbs have me baffeld
My freind has a bug that wont stop missing. It has new point, condencer, cap, roater, wires and plugs. Its a stock 1600cc with a 009 distributer. Everything has been run on it. Checked whe vales, points, timeing etc. timing is at 7 degrees for the 009. at idele it shakes a bit (leads me to think broken motor mounts) and when the rpm is up it still misses. Id say @ 2000prm it misses about every second or so. The compression is 120 on all 4 cylenders. any ideas out there?
------------------ Sweet Blue 72' 914 Check it out at http://www.geocities.com/eat_um_up/914.html |
Intake leaks?????do some sniffing with a can of starting fluid )very carefully)..
Hey buddy, Is ur friend running a 34pict-3 carb?? If so, its gonna have a flat spot when u step on it.
Is the firing order right? Has the carb been properly dialed in, sounds like its running lean. Believe it or not, on the dual port (I'm assuming its a dual port engine) the dual vacuum advance dist.works better than the 009. Unless you've got the 110 or 120 cam in it, the 009 will work well. If it is the stock bumpstick, stay with the vac.advance dist. Check out the Kymco motorsport website for tuning procedure on the 34pict-3. You'll need adobe acrobat to download the info. Oh, one more thing...timing is set at 7.5 degrees for the 009. Is the miss only at higher rpms? Double check the timing,set the ldle, and check that carb. The big screw on the drivers side of the carb is for idle. The small screw just beneath it is for mixture. Good Luck!! John. ------------------ 72'914 [This message has been edited by chibone_914 (edited 08-17-2001).] |
| All times are GMT -8. The time now is 11:45 AM. |
