Inschool's Avatar
Side shifter is this normal
I am gathering parts to swap to the side shifter transmission, I bought the shifter a short time ago and while cleaning and prepping it i noticed that the shifter shaft is not completely straight on with the mechanism below.
Is this normal, or is it twisted? The picture is taken if i were looking at the top half of the shifter straight on.
No minivans!
Old 10-28-2007, 02:14 PM
914turbo's Avatar
It's possible that the epoxy bond holding the shift lever to the lower portion (semi-ball shaped part) of the lever is failing. Put the lower part in a vice (w/ covered jaws) and try to twist / turn the shift lever. If it turns at all, you have to remove all the old epoxy and re-epoxy it (or weld it).
2001 996 Turbo Coupe - Tip w/ Mods SOLD
2004 996 Carrera Coupe- Tip SOLD
Waaaay too many previous Porsches (25+) and VW's (50+) to list
Old 10-28-2007, 06:11 PM
Groucho Marxist
Tobra's Avatar
before you go sticking it in a vise, compare it to a known good one, some of those shifter pieces have some kinks and bends in them.
"Keep your eye on one thing and one thing only: how much government is spending, because thatís the true tax ... If youíre not paying for it in the form of explicit taxes, youíre paying for it indirectly in the form of inflation or in the form of borrowing."
Milton Friedman
Old 10-28-2007, 08:11 PM
I have welded everyone of the ones I have had. never had a problem again.
Yea make sure you line it up like you want 1st.
Old 11-07-2007, 04:29 PM
Inschool's Avatar
The epoxy is fine, every shifter i have ever come across has been epoxied together. My question is the alignment ok. I don't want to get this thing in the car and find out that the shifting is awkward due to alignment.
Does anyone have a pic of a knowngood shifter.
No minivans!
Old 11-12-2007, 05:59 PM
