Front Suspension rattle What am I missing?
I'm trying to work through a front suspension rattle when going over bumps. I replaced front strut inserts, tie rod ends, and re-tightened the wheel bearings. I also re-checked the front mount nuts for the strut inserts to make sure they are tight. I am still getting the rattle when driving over small bumps. I noticed that after I adjusted the wheel bearings, I had play in the bearings come back after the test drive, so I suspect the bearings may be shot and adding to the problem. Is there anyting else I should check that I may be missing?
Nowlings
Old 10-28-2007, 08:06 PM
Check your brake pad anti rattle clips. Brake pads can rattle like hell if they aren't in there. Easy way to tell is to hit the brakes slightly when you are hearing this rattle.
Old 10-29-2007, 11:52 AM
thanks for the tip... I will check tonight
Nowlings
Old 10-29-2007, 12:29 PM
shock pistons don't fit snug in the shock mount. there are different diameters and a fitted bushing will fix it.
Old 11-07-2007, 04:25 PM
Thanks.... I located the issue which ended up being a loose strut insert. Removed strut and resecured insert and re installed. OK now.. Thanks for the input.
Nowlings
Old 11-07-2007, 08:20 PM
Cool What do I win?????
Old 11-08-2007, 05:17 PM
