Post Tire pressure Komo's
Going to 700 VictorRacers on the Track car. What tire pressures has any stated with I understand thay like higher pressures than Yokos,ect Looking for track pressures only Thanks
Old 08-22-2001, 02:04 PM
Stay away from my Member
campbellcj's Avatar
Post
I haven't had the Kumhos for too long but I've been running them at 40psi HOT which is what was recommended to me by several racers...seems to work so far.
Old 08-22-2001, 03:41 PM
John Rogers's Avatar
Post
I have 205s on our stock class car and run 26 pounds front and rear. A temp check with the pyrometer at the last auto-x showed temps within 1 degree all the way across. Try to get temp readings at the next track session as looking or feeling won't work. Good luck.
Old 08-22-2001, 07:02 PM
campbellcj's Avatar
Post
John - you're running 26 hot at the track? Or is that your cold starting point?
I've been running 30-32 cold (i.e. street) and 38-40 hot at the track. I figured lower pressures would lead to undesired sidewall flex/rollover. I haven't taken pyrometer readings yet...gotta do that someday.
Chris
Old 08-22-2001, 09:40 PM
Jim Smolka's Avatar
Post
I too am interested in the tire pressure recommendations.
I have the Komo 700 on my car for DEs, but I have not had the chance to put them on the track.
I will vary the pressure some and see what happens. I hope to be @ VIR in Sept (waiting list) and at CMP [Kershaw] in October
Old 08-23-2001, 05:03 AM
Post
I run 27# front 26# rear cold which ends up being 31 -30 hot. With the stiff sidewalls you can run lower pressures. Also with 7" wide rims and 205 tires prevent the tire from rolling over. I loose grip with anymore pressure and it is very noticeable.
Old 08-23-2001, 06:16 AM
Post
That pressure is hot. I have 6 inch wide rims and get a little roll over but not bad. I was more concerned with the grip across the face of the tire which looks pretty even. A pyrometer is a rgreat thing to have as it can be used for many other things like reading head temps, transmission temps, brake rotor temps, etc. Good luck
Old 08-23-2001, 06:22 AM
campbellcj's Avatar
Post
Thanks guys...next time out I'll buy/borrow a pyrometer and try some lower pressures. Unfortunately I'm currently running 205's on 5.5" wheels, which I'm not a big fan of doing but I'm class-limited to 6" anyway. If a pile of money falls on my head I'll pick up a set of Panasport Racing 15x6's, or maybe do a 5-lug conversion and go to 911 Fuchs.
Cheers,
Chris C.
73 914 2.0
70 911E Targa
campbell.chris@gte.net
Old 08-23-2001, 08:08 AM
