earlr85944's Avatar
thermostat wire broken \ running hot
I just looked under the car because its running on the hot side and its cool out. I found the thermostat wire is just hanging, where does it go. Also on the bottom of the motor is a round plate with a wire comong out of it, is that where the temp sender goes?
OH, its a 74 914 1.8
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 11-20-2007, 04:07 PM
The tstat cable goes up from the bellows then forward to the bar between the flaps at top/front of motor. When the cable is broken/disconnected, the flaps should default to full cooling position. Double check it... Grab the bracket on that bar where the cable is supposed to attach, rotate the bar (moving the flaps) then let go. There is supposed to be a spring which will make them snap back. If so, then your overheating problem is not because of the broken thermostat cable. If not, you need to lock the bar into full cooling position.
Yes, the round "taco" plate on the bottom of the motor is where the oil temp sensor wire connects.
-Rand
Old 11-20-2007, 04:24 PM
earlr85944's Avatar
Thanks for the info, I will check this today. Is the bar accessible from the top or bottom of the car?
83 944....bye bye
Old 11-21-2007, 05:05 AM
Headrage's Avatar
The top, along the rear edge of the fan shroud.
Old 11-21-2007, 08:59 AM
earlr85944's Avatar
Thanks, found the flaps. Prob turned out to be a loose fan belt.
83 944....bye bye
Old 11-21-2007, 01:43 PM
Groucho Marxist
Tobra's Avatar
loose fan belt will make a type I VW run hot, not a type IV. Fan on I is run by belt, fan on IV is not, it is on the end of the crank. Check your timing or for leaks on intake side if it is running hot. Turn idle screw, if nothing happens, likely air leak, leads to lean condition=hot running
"Keep your eye on one thing and one thing only: how much government is spending, because thatís the true tax ... If youíre not paying for it in the form of explicit taxes, youíre paying for it indirectly in the form of inflation or in the form of borrowing."
Milton Friedman
Old 11-21-2007, 07:06 PM
earlr85944's Avatar
I will try that, I found the belt loose and assumed it was driving the fan. I also need to install gauges(oil pressure and oil temp \ head temp) to see whats going on.
83 944....bye bye
Old 11-21-2007, 08:41 PM
earlr85944's Avatar
hate to say but the car was converted to a single carb..... before I got it.
83 944....bye bye
Old 11-21-2007, 08:42 PM
earlr85944's Avatar
turned out not to be running hot, the po installed a temp sender that goes under the spark plug which measures cyl head temp and wired it into the stock gauge that measures oil temp, so the reading shows higher than it should
83 944....bye bye
Old 12-21-2007, 04:26 PM
