-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Fitting engine lid (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3799-fitting-engine-lid.html)
smpiers 08-23-2001 04:14 AM
Fitting engine lid
I cannot get my engine lid to fit well at all. Is there a secret? I have moved it around as much as I can. The lid wants to hit the rear trunk lid.
Shane
JmuRiz 08-23-2001 05:50 AM
Try adjusting the rear trunk lid. It's easier to mess with that than the engine lid IMHO. An extra set of hands to wrestle the trunk is a good idea, good luck http://www.pelicanparts.com/ultimate/biggrin.gif
Nathan
'73 2.0 914
guards73/2.0 08-24-2001 09:18 AM
Sometimes the "L" brackets that the engine lid bolt to break their welds at the top and bend rearward, causing a clearance problem with the lid-to trunk clearance. I'd check those welds
kingjp914 08-24-2001 09:22 PM
I had the same problem once. The passenger side L-bracket cracked at the fillet and bent downward. It shifted the lid to the point where it wouldn't close unless I pushed the lid forward and then downward. I ended up removing the lid, had my buddy re-weld the bracket and then we put the cover back on. The cover didn't want fit well at all so I made the slotted holes a bit bigger on the engine cover. Two sets of hands was the key though. I just couldn't get it to fit by myself.
