How to replace fuel pump?
Im buying a 73 and it still has the FI system. The owner says the fuel pump needs replaced.
Anyone explain what needs to be done and how difficult it will be?
Thanks.
Old 11-29-2007, 09:53 AM
it's fairly straight-forward, though I'm writing this from memory...... in your front trunk just behind the spare wheel is a bulge in the carpet. Lift it up and undo the 2 bolts in the middle of the black cover, then undo the 4 bolts holding the cover on. With the cover out of the way you can then see the pump in all it's glory. The tricky thing I found was undoing the clamps holding the fuel lines on in such a confined space - you may find it easier to remove the tank.
But the 1st question you need to ask is - why does the previous / current owner think it's the pump that needs replacing? It may be worth getting a 2nd opinion.
Old 11-29-2007, 10:42 AM
DOH! just re-read your posting - your pump is more likely to be in the engine compartment!!!! Hmm, must really start reading more carefully.....
Still think it'd be good to get a 2nd opinion tho
Old 11-29-2007, 10:52 AM
Groucho Marxist
Tobra's Avatar
Replacement is straightforward. I would consider moving it to the front. You will want to replace rubber fuel hoses and the filter concurrently.
You don't necessarily have to use same type of pump. The style pump they used on the later '75+'76 cars can be had for much cheaper. I believe someone has a kit to move the pump up front, down to the bump in the trunk to mount the pump, mine is down by the steering rack
"Keep your eye on one thing and one thing only: how much government is spending, because thatís the true tax ... If youíre not paying for it in the form of explicit taxes, youíre paying for it indirectly in the form of inflation or in the form of borrowing."
Milton Friedman
Old 11-30-2007, 11:09 AM
