Correct clutch for 914/6 conversion
I am still working on my 914/6 conversion. My shop is now mocking up all the engine parts for the installation and I still a need a clutch and I am not sure which clutch I would need.
I am installing a 2.5L (originally a 2.4L block) to the stock 901 that was in the car. Anybody help would be greatly appreciated.
Old 12-17-2007, 06:32 AM
thesey914's Avatar
your four cylinder friction plate and pressure plate will owrk fine. You obviously know about the six bolt flywheel.
Old 12-17-2007, 09:36 AM
Yes I have the correct flywheel. Will the stock clutch be able to cope with 210 hp?
Old 12-18-2007, 06:17 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Yup, it should be able to. KEP makes stiffer pressure plates if you want to be extra sure.
--DD
Old 12-18-2007, 07:18 AM
Senior Member
I'd go (& did so) with the Kennedy Stage I & the stock 6 spring disc.
The combo has held up very well behind my hot rod 2.7L. for 7 years....so well that when I rebuilt the motor this last couple months I didn't hesitate to just put all of it back in.
JPIII
Early Boxster
Old 12-18-2007, 02:33 PM
jhora's Avatar
Street ...stock one is fine..
Track / Autox....KEP or Centerforce
Old 12-18-2007, 08:13 PM
rfuerst911sc's Avatar
I hope tommott doesn't mind me glomming on but I'm doing a /6 conversion useing a 3.0 with a 901 tranny. I have purchased the "special ring gear" that supposedly will allow me to use the 3.0 flywheel. So what pressure plate and clutch disk should I use? I want to use OEM Porsche parts if possible. Anyone have part numbers of what I need?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser.
Old 12-19-2007, 01:04 PM
iamchappy's Avatar
Kennedy stage 2 clutch and pressure plate package for the 3.0 901 setup.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 12-19-2007, 05:15 PM
SirAndy's Avatar
i'm running a KEP 2-Stage with the 993 flywheel and the 901 tranny. supposedly good for 500HP/Torque ...
Andy
>> 1970, 914-6, 3.6L TT4/AX4 - Shall I say... 3.6 (My conversion thread)
>> 1970, 914-6, #374 (Original) For sale!
Old 12-19-2007, 05:28 PM
sww914's Avatar
I just helped my friend do this one a couple of days ago. You need to use the regular 914-4/ 914-6/ early (pre '71) 911 disc and pressure plate with the special bolts that were supplied with the "special ring gear". You also need the "special throwout bearing".Search PP for the clutch and pressure plate part numbers by application.
Old 12-19-2007, 07:02 PM
Randal.'s Avatar
If you want original I have a Sachs light weight pressure plate and clutch. It was run for 4 minutes only.
Randal
randalbarrick@msn.com
Randal
Old 12-19-2007, 07:23 PM
Randal
Randal please PM me with details,price etc. Thanks
Old 12-20-2007, 01:36 AM
Unfortunately I didn't get any " special bolts " with the special ring gear. So what makes the bolts special? And what is a " special throwout bearing " ? What makes that special? Thanks
Old 12-20-2007, 02:28 PM
sww914's Avatar
There's 2 types of bolts on the ring, the short ones that hold the ring in place, and the long ones that hold the pressure plate and the ring on. The special throwout bearing fits in the 901 fork and I don't know what else was so special about it, but it came with the kit.
Old 12-20-2007, 02:52 PM
