185/65 tires, how will look on car versus stock 165 tires or 185/70?
Will be buying new tires to put on a set of Pedrinis. Wanted to go with 185/70 tire size to replace the 165 standard tires now on the car as the 185/70's are about the same diameter. New 185/70 tires are not available for a decent price (if at all). 185/65 tires are available but the diameter is 1 inch less. Anyone have a picture of how these look on the car with the shorter diameter? I could go with 195/65 tires (also close to stock dia.) but I believe they might rub against A/C lines in the front (and maybe back) of my fender wells?
Comments/photos?
Thanks,
jjs3rd914
Old 12-19-2007, 03:47 PM
What profile ratio are the original 165's (75, 70, 80?). I think to compare the same size tire-wheel combo just multiply the width (165mm times the aspect ratio 65% for 165/65/15)=ytimes new ratio or the correct width=165*0.65/0.70
Old 01-01-2008, 04:57 PM
Thanks for the reply. I beleive the original 165's were 80 series. All the tire calculators reveal the following,
165/80 have 25.4" dia tire that was on the car
185/70 have 25.2" dia
185/65 have 24.5" dia tire now on the car which is 0.9" less than original
195/65 have 25.0" dia
I went with 185/65's because 185/70's are not available for a decent price. I wanted a wider tire than 165/80 but was reluctant to go too wide as with the 195/65's because of the mentioned A/C lines. Plus 185/65's are plentiful and less expensive. The 185/65's are on the car (yesterday) and look fine. I will post a picture shortly.
Thanks,
jjs3rd914
Old 01-01-2008, 05:49 PM
Pedrinis with 185/65 tires
Here are the 185/65 tires mounted on Pedrinis. We may lower the front just a hair to fill the wheel well a little more. Otherwise the almost 1 inch less in dia. from the stock 165/80 tires does not seem to be that noticeable.
jjs3rd914
Old 01-01-2008, 06:10 PM
SirAndy's Avatar
http://www.914world.com/specs/tirecalc.php
Andy
>> 1970, 914-6, 3.6L TT4/AX4 - Shall I say... 3.6 (My conversion thread)
>> 1970, 914-6, #374 (Original) For sale!
Old 01-01-2008, 09:14 PM
Looks Great. I think the Fuchs look great on a 914.
It looks as if the front end on your car is lower than mine. Looking at the distance between the rim and the fender lip , mine appears much larger. Did you lower yours after the smaller dia. tires were installed? The rears look about the same. When I took my photo the gas tank was almost empty so that may contribute a little. Once filled I may lower the torsion bar screws to get a more even look.
Again thanks for the post as it gives all of us a bench mark when it comes to getting new tires of a different size than the original 165's.
jjs3rd914
Old 01-05-2008, 04:21 AM
bandjoey's Avatar
diso**** tire tires
Went to Discount tires and bought Barum (Braziliam) tires 195 60 complete with lifetime everything installed for $294. They're on Perdini wheels. Look great and good price.
Old 01-05-2008, 09:49 AM
I'm running 215/65 tires on the stock 5.5 inch rims- probably a wee bit too wide for the rims, but they don't rub anywhere.
1989 928 S4 5spd lsd Black/Burgundy
1975 914 2.7L 4cyl Toreador Red
Old 01-19-2008, 06:15 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
215s? You're a very lucky 914 owner! Very very few cars indeed can fit 215s under stock fenders.
--DD
Old 01-20-2008, 11:33 AM
If you notice the 72 914 behind the red one, it too has 215/65 tires, same rims. No rubbing, no pulling out the fenders to fit. Actually this one will rub the inside if the wheel is hard over.
Old 01-20-2008, 12:14 PM
