-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Weber 2 X 34 Ict Conversion Kit (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/383555-weber-2-x-34-ict-conversion-kit.html)
Spievy 01-11-2008 01:35 PM
Hey thanks guys for your input. If she is thirsty that is fine with me, not like I drive it to work everyday.
It was warm the other day and I decided to time the ignition. Seemed to be way off. So, I timed it to 35 degrees @ 3200 rpm (that was fun and loud). This was the first time I had timed it since I bought it. I haven't had a chance to road test it but I will probably this weekend. Hopefully it wont bog down @ 2250 rpm like it was doing. I will let you know, how it goes!!
jhora 01-11-2008 03:30 PM
You're right a fun car getting that milage is fine...
Yes isn't it fun to check the timing....loud...very loud...should help the bog...
