Distributor Rebuild on 2.0 FI
Does anyone know of a rebuild kit or reliable rebuild source for the 2.0 FI distributor. Would like to replace weights, cam, fiber bushing, etc. My FI points look almost new (under 20K on them). I can't find a rebuild kit or rebuilder?
So far, the two posts below don't answer my question and the Cardone units are iffy for what you get (I was an old aquaintance of Nick Cardone from Philadelphia in the Carb business 16 years ago and I helped liquidate the carb plant for a bank). So far my research notes that the VW Bus motor may use the same Distributor with the FI points... Maybe a VW rebuilder? Thanks Joe [This message has been edited by retro74 (edited 08-31-2001).] |
I'm not aware of any available 2.0L FI distributor rebuild kits.
Individuals here have found that A1-Cardone has rebuilt units that can be cored/purchased at most major FLAPS. |
FI trigger points can go 100K miles so the ones you have are reusable. Stock rebuilt dizzies are readily available. Be sure to double check the original part number for a match. I would not waste my time trying to rebuild an old dizzy.
| All times are GMT -8. The time now is 09:54 AM. |
