Addicted to Racing
edbaus's Avatar
Piston Problems
Hi,
I was pulling apart a 2.0 motor that is primarily used for track events. It has about 4 years of about 10 events a year on it.
It is down for rebuild because it was starting to blow oil through the rings.
Take a look at the picture. The piston pins seem to have a thrust load on the clips that hold them in. This one piston is the worst, but they all show signs of this.
What could cause this to happen.
Ed
Old 12-31-2007, 12:47 PM
Ask Jake at Aircooled techonology
Old 12-31-2007, 06:02 PM
Bent rod...
Too much rod side clearance...
Pin length too short allowing the pin to thrust...
Cylinder bored off center, forcing the piston sideways in the bore....
That piston is toast...
Jake Raby
Flat 6 Innovations and Aircooled Technology
IMS Solution Inventor
US Patents:8,992,089/ 9,416,697/ 9,687,974/ 9,909,369
'64 356C Outlaw,'76 912E,95 993,89 964 &'88 Carrera
Old 01-03-2008, 08:41 PM
