-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   need help tuning webers (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3888-need-help-tuning-webers.html)
toman 09-02-2001 03:51 PM
I need some help tuning my webers. They were running allright, but a little rich until a family member decided to "help" me adjust them. Now the car barely runs, and I don't seem to be able to get things straightened out. Also, when I listen to one carb through a hose, it makes an odd flapping noise. What does this mean? Any help would be very much appreciated.
chibone_914 09-03-2001 09:28 PM
The easiest book I got on the subject is called the "Weber Tech Manual" by Bob Tomlinson sold by CB Performance. Give em' a call and order it.
It goes over everything from its origins to setting up to fine tuning. A very handy piece of reference.
Good Luck,
72'914
John@pelicanparts.com
[This message has been edited by chibone_914 (edited 09-03-2001).]
SteveStromberg 09-04-2001 07:03 AM
Check this site it deals with DOCE's but the principal is the same.Steve
See: http://www.geocities.com/Baja/Canyon/1017/weber.html
John Rogers 09-04-2001 11:48 AM
You most definately need the Weber book and it available at most autoparts stores such as Pep Boys, Kragen, etc. You also need a flow meter which you make have to order from PP or CB so you can accurately measure each cylinder flow. Don't try to do it by ear as it is too hard. Since you did not say which Weber model you have a guess would be that they are too lean. A basic adjustment is as follows: 1. Remove the air cleaners, 2.Unhook one carb from the cross bar linkage, 3.Adjust idle speed screw until the buterflys just move off closed, 4.Open mixture adjust approx 1.5 turns from closed, 5.Close the air adjustment screws, 6.Start the engine but don't hit the throttle and let warm up some, 7.Measure each cylinder airflow and adjust idle mixture and speed as per Weber manual, 8.Shut off engine when finished, 9.Hook up cross bar linkage, insuring the throttle plate on the carb does not move, 10.Start the engine and recheck the air flow for each cylinder and readjust as necessary. Good luck
