Hella High Beams Don't Shut Off
I recently installed Hella lights with the 55/100 bulb. When the fog lights are on the high beams will not switch back to low. I must turn off the fog lights before the low beams can be re-engaged. A relay was included with the light installation. Any suggestions as to where the problem is?
Old 11-13-1998, 03:22 PM
Still searching for an answer...
Old 12-05-1998, 09:40 AM
Try to swap the two positive wires, you probally have the wire that is always on connected to the high beam element.
Old 12-06-1998, 02:36 PM
