Hella High Beams Don't Shut Off
I recently installed Hella lights with the 55/100 bulb. When the fog lights are on the high beams will not switch back to low. I must turn off the fog lights before the low beams can be re-engaged. A relay was included with the light installation. Any suggestions as to where the problem is?
Still searching for an answer...
Try to swap the two positive wires, you probally have the wire that is always on connected to the high beam element.
