velocity stacks????
any one out there kknow where i could get a set of vellocity stacks for a pair of dell 36's tall ones can be used because theres loads of room!!second hand is good !!!!
Pod:
Hop on over to the CB Performance pages (don't have the URL handy) and dilly around there - they still got stuff for Dells, but no floats last I checked. I was at car show in Ensenada recently and saw a whole set for the Dells - Cheap! Check out your local swaps, etc... If you're feeling manly and have access to a drill press, you can even fit the DRLA Update Kit to the 36s, even though they are not specifically made for that application - I adapted a kit to the 36s I got on my '73 1.7L motor. Whatever you do, don't try to use the 34mm venturis they pack into the 40 DRLA Update Kit - AMHIK... Motornut |
If you need some spare Dell parts i have some from DLRA 40 used to be's i found some for cheaper than rebuilding (so i thought, hat to rebuild the new ones too couse they were turned into 36's) and did it.
------------------ Sweet Blue 72' 914 Check it out at http://www.geocities.com/eat_um_up/914.html |
| All times are GMT -8. The time now is 08:47 AM. |
