Send a message via ICQ to macman
Post 1975 1.8 fuel injection wiring
i am currently haveing a problem with my 75 914 1.8leter that you may know the solution to. i have a double relay connected to the brain harness about 3 feet from the brain, but i can't figure what the other side of the relay is supposeto hook up to. is their an additional wire leading from the relay box? should the main engine harness have a connector on it? the relays are square and hook under the battery.
Michael Scheid
(206) 232-9854
Old 09-10-2001, 02:17 AM
Post
The engine harness for the 1.8 is different from the 1.7/2.0 It has an additional plug that hooks to the double relay. There is also a power lead that connects to the battery positive lead, and a small single wire that comes off the harness at the relay board end, and connects to the 4 pin connector for the d-jet injection. It turns on the fuel pump.
I have a harness if you are interested in getting one.
Clay Perrine
74 1.8L Signal Orange "Frody" (My Wife's Daily Driver)
73 2.4L MFI Six "Igor" (Under Construction)
"Friends help you move. Real friends help you move all your 914 parts"
Old 09-10-2001, 09:28 AM
