cary's Avatar
Post turn signals ??
Starting to "tinker" on my project car. Just noticed the turn signal indicator light doesn't work. I read the wiring diagram I see there is only one wire coming to the bulbs.
So both must "blink" when the turn signal is turned on ?
Mine is also missing the ground wire. Where does the ground come from ? The bulb holders are plastic, so not there. The schematic shows green coming from the high beam indicator light. Or is that internal in the tach ?
TIA
Cary Kutter
77 Euro Carrera w/3.2
74 914 2.0 ( base model )
PCA Region - Big Sky
Old 09-15-2001, 04:50 PM
Send a message via AIM to JP Noonan
Post
The ground is through the gauge body, look at the plastic bulb housing and you'll see small grounding tabs on it. The gauge gets a brn wire that daisy chains to the other gauges.
If this still dosen't help, ,clean off the grounds behind each headlight as I had a similar problem and it turned out to be the grounds.
Old 09-15-2001, 07:33 PM
