-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   1.8L cylinder bored to 96mm, possible? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/399677-1-8l-cylinder-bored-96mm-possible.html)
WillowGreen 03-22-2008 11:49 AM
Hi, I read many suggesting boring out OEM 2.0L cylinders for 96mm pistons. Can I bore OEM 1.8L jugs out for 96x71mm setup with 1.8 heads? I wonder if the height with 1.8L jugs are different from 2.0L.
Dave at Pelican Parts 03-22-2008 02:32 PM
The 93s can absolutely be bored out to 96mm; they are the same OD as the 94s from the 2.0 cylinder.
The height should be fine as well. Just make sure you get 96mm pistons that are intended for a 1.7 or a 1.8, because the height of the pistons is different on the 2.0 .
--DD
WillowGreen 03-23-2008 06:35 AM
--DD
DD, as mentioned I'm building 96 x 71 with 2.0L crank. Can 1.8L jugs bored out to 96mm work?
Dave at Pelican Parts 03-23-2008 08:55 AM
Yes, as long as you get the 96mm pistons that are intended for the 2.0 crank/rods.
--DD
WillowGreen 03-23-2008 11:54 AM
--DD
Good deal. Thanks for your help.
