I am about to embark a 6-hour drive - to the East Coast Ramble in NY state - with my newly completed 914/6 conversion.
What first aid kit - parts, tools, etc - should i bring with me to cover the basics and the not-so basics. Also, is there some sort of list of 914 generic troubles and their solutions that someone coul lead me to? Thanks to all. |
umm ,
13mm socket+wrench 11mm " " 10mm " " Ratchet Creset wrench phillips and flat head screwdriver black tape portable jack flashlight and rag... cant think of anything else ------------------ Sweet Blue 72' 914 Check it out at http://www.geocities.com/eat_um_up/914.html |
AAA card and enough on a credit card to get it home. I'd try to get several hard runs in locally before you go to see if it has any problems and try a run in the rain to see what happens when it gets wet too. I took tons of 914 parts on our 800 mile to the porsche Parade last year and our Turbo burned up the CDI box! Go figure. Good luck on the run.
Senior Member
Hello
Depends on the quality from the conversion. I would recomend spare fuel and oil and a AAA policy. $ help too. Grüsse |
Also a 911 alt belt. Might not be able to replace it with the motor in the car though.
I would also take a tool to tighten up the CV bolts |
I just finished my conversion several weeks
ago. Put about 3 hundred miles on it and had a Exhaust rocker shaft back out. I am replacing it today but will not take it to the ECR until I but a least 2 - 3 hundred trouble free miles on the engine again, so we will be taking the 911 to ECR. I also need new Tires and alignment done. I would take an Extra set of plugs... Fire Extinguisher... Some type of Jack and jack stands. Extra Clucth and throttle cable ------------------
How 'bout a couple quarts of motor oil.
Passport, and food for while you wait at customs.
Duct tape, vise grips, silicone, work gloves, hand cleaner, lots of cash. [This message has been edited by DDS (edited 09-23-2001).] |
Let see ... what would I always carry (for long trips)?
Put a few thousand "sortin' out" miles on your "newly completed 914/6 conversion" first, before you attempt/risk a journey like that. It's 6-hours there AND 6-hours back; quite a long walk, I think.
