-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   AAAUUUGGGHHH !!! (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/4080-aaauuuggghhh.html)
J P Stein 09-29-2001 01:37 PM
AAAUUUGGGHHH !!!
If anyone is interested, failure of an external oil thermostat to close, thus routing cold oil to an external oil cooler
gives you this:http://www.pelicanparts.com/ultimate...oolerblow1.jpg
J P Stein 09-29-2001 01:42 PM
folowed by this:http://www.pelicanparts.com/ultimate...oolerblow2.jpg
A fine mess.
JPIII
echocanyons 09-29-2001 02:41 PM
JP,
And your garage WAS so clean.
You didnt blow this while the car was running did you?
Was this all due to a bad thermostat?
Kelly
J P Stein 09-29-2001 03:57 PM
I was starting the car in the shop preparing to go autocrossing.
Tho I haven't pulled any parts yet, the thermostat (external) is supposed to route cold oil around the external cooler.....just to protect it from excessive pressure. No oil should have been going that way.
It pumped out about 10 quarts in maybe 20 seconds. All thru a split maybe 1 1/2 inch long X .03 wide.
A fine mess.
Troutamn thermostat, BTW.
JPIII
JPIII
sacook 01-02-2003 02:00 PM
JP....just courious, where did you mount your external oil cooler?
SAC
chrisreale 01-02-2003 02:20 PM
Bummer:( At least it happened stationary, and not while driving.
sammyg2 01-02-2003 02:20 PM
LOL, I bet JP's gonna be real happy to see this thread come back to life.
(inside joke).
scg 01-02-2003 04:21 PM
Oh geez.... I should've known someone would have to start this up again (sorry, JP)!;)
red-beard 01-02-2003 08:22 PM
Bad 914. BAAAAAD!!!! BAAAAAD!!! (swap with newspapers on the nose)
