Eat-um-up's Avatar
Send a message via ICQ to Eat-um-up Send a message via AIM to Eat-um-up
Question Bone head fuel pump question
This feels like a dumb question but here goes. Im pritty sure the fuel pump is no good
but on the off chance is there a way to fix it?? When it worked it used to make a low quiet humm. now it clatters extreamly loudly. it does not seem to be pumping ither. is there a way to fix that?? or where and what kind should i buy to replace it?? im running duel 40mm dells
Sweet Blue 72' 914
Check it out at
http://www.geocities.com/eat_um_up/914.html
Old 09-30-2001, 01:57 PM
Senior Member
Post
Hello
The EFI fuelpump is not designed to be choked down to a carb setup.
I think it will leave this world in a while.
Rebuilding is possible.
Grüsse,
Roland
Old 09-30-2001, 10:00 PM
Eat-um-up's Avatar
Post
its not a stock fuel pump. it was changed when the conversion was done. that much i know. but thanks. ill look into fixing it
James
Sweet Blue 72' 914
Check it out at
Old 09-30-2001, 11:46 PM
