HarveyH's Avatar
Post Oil Temp Gauge
I'm accumulating parts for an external oil cooler per the Pete Dubler article. Additionaly, I'm going to put in an oil temperature guge with real numbers. I plan to run new wires and put the new gauge into the stock position in the sump, and move the OEM sensor to a fitting in the oil return line from the cooler/thermostat. Will Teflon tapeseal cut through enough to give a good electrical contact when installing the sensors? Any other techniques to getting these into position and getting good connections?
Thanks,
Harvey
Old 10-02-2001, 04:11 PM
