Post Brass t fitting on Master Cylinder
Does anybody know where I can find a brass t fitting that splits the front brakes off the master cylinder? I stripped one of threads, which in turn caused a galling mark on the mating surface. The part looks like an earlimyer flask from chem class, but has a hole in the body of it.
I would think these are standard type parts, but my local german parts house says I'm S.O.L.
Old 10-02-2001, 07:20 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
I will check I think I have one on one of my hulks. Steve
Old 10-02-2001, 08:25 PM
jabb's Avatar
Post
I know the early 911 calipers use the same fitting. If you have a german parts house near by that has some core calipers maybe they will give you one from the caliper.
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
[This message has been edited by jabb (edited 10-03-2001).]
Old 10-03-2001, 05:41 AM
Post
I believe the part you are referring to is called a "banjo fitting". The bolt that goes through it ii hollow, with openings for the banjo 's interior. There are thin metal washers that go on both sides of the fitting.
Old 10-03-2001, 12:23 PM
