Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
914 Carb conversion Question
I'm installing a set of Webers to a re-built 1.8l engine into a '72 914. I have read recommendations to install an secondary fuel pump and .009 distributor. Is this a necessity to get the engine to run or should it work with the stock fuel pump and distributor from the FI system? Thanks.
Old 06-02-2008, 07:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
djpateman's Avatar
A stock FI fuel pump putting out 20 to 30 PSI compared to a fuel pump for carbs putting out 3 to 4 PSI are two different things altogether.
Keeper of 911, 912 & 914 databases Kardex source
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 06-03-2008, 05:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
bluemm's Avatar
You will need a new fuel pump and fuel pressure regulator. I recommend an adjustable regulator. I used a 4 psi pump and an adjustable regulator capable of 1 to 7 psi in 1/2 pound increments. Works great.
Old 06-03-2008, 04:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
HarveyH's Avatar
You also don't need the 009 distributor. The 009 advance curve is specifically for the VW Ty 1 engine. Any of the stock 914 distributors have a much better advance curve for the Ty 4 engine. Depending on the model of carb you have, there may be a small screw-in plug that seals a vacuum port. Remove this plug and run a hose from the tube on the carb to the advance side of the distributor dashpot. Even without the use of vacuum advance the stock distributor is better than the 009.
Harvey
Harvey
Old 06-04-2008, 03:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
jaybird840's Avatar
Send a message via Skype™ to jaybird840
+1 on ditching the 009. My 1.8 had a 009 installed when I acquired it, and it sucked! Do yourself a favor, spend the $300 on a Mallory Unilite offered by Jake Raby or Chris at Tangerine Racing. I was soooo glad I did. It is truly "set it and forget it." Worth every penny.
Jaybird
'75 914--slowly becoming a supercar
2.7RS spec rebuild in progress
Old 06-04-2008, 02:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
SGB SGB is offline
SGB's Avatar
However, the engine will fire and run with the stock diz using carbs. I don't use a pressure regulator, but you must use a LOW pressure fuel pump. The are inexpesive here at PP.
-Scott
My gallery page
Old 06-13-2008, 06:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Joe Bob's Avatar
Did you ditch the stock fuel injection profile cam shaft?
See me for graphics. www.nbdgraphics.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 06-14-2008, 09:33 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
SGB SGB is offline
SGB's Avatar
I don't think he did. Same with the diz. Right now I think its just carbs on manifolds. Soon to be joined by a low pressure pump.
-Scott
My gallery page
Old 06-15-2008, 04:10 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
JW Apostate
trekkor's Avatar
I'm still trying to find out if the Euro TypeIV with carbs used a different cam.
KT
'74 914-6 2.6 SS #746
'01 Boxster
'73 914
Old 06-15-2008, 04:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
No, it did not. Same part number, same valve opening/closing points, and I believe the same lift.
--DD
Old 06-15-2008, 07:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
a self regulated low presure fuel pump is what you need. remember, filter prior to the pump.
k
here? not so much i think. high five!!!
Old 06-22-2008, 05:37 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
