Suspension Setup Article - Need your input!
I've noticed several posting about rear suspension setup, and I'm at the point where I need to do something with mine as well. I would like to gather as much detail information about current setups and compile this for a PP Tech article (all contributors will be mentioned in article).
Here's what I need: <UL>[*]Rear shock manufacturer & model[*]If adjustable shacks were used, note which setting is being used.[*]Rear spring manufacturer & weight (100, 110, 140, etc) - also note if any cutting was done to reduce unsprung height, then also provide installed height of spring.[*]Tire size (205/65-HR15)[*]Wheel size 15x5.5[*]Rear - Left & Right measurements: measure from level floor to circular jack pad (under car).[*]Front - Left & Right measurements: same as rear.[*]Add any pertinent info that would affect final ride height, like; V8 installed, or mother-in-law in trunk.[/list] I might suggest that contributors cut&paste this list into an email (with your data added) and send to me directly. Thanks, ------------------ Gerard 74-914 2.0L 3D914 rodrigos6@juno.com |
Here is my setup.
180 Springs. Koni Adj Sport Shocks (lowest setting) Poly type bushings from Pelican Stock trailing arms. Tires: Street Tires 205x16x55 on 16x6 Fuchs Old Track Tires: 205x16x55 on 16x6 Fuchs New Track Tires 225x15x50 on 15x7 944 Phone Dials [This message has been edited by Jim Smolka (edited 10-13-2001).] |
Here is my rear set up on the rear:
-adj. rear spring perches -225lb rear springs -ext. adjustable koni shocks -boxed trailing arms -braced suspension console -7 x 15 inch rims -hard poly bushings -rear welt. sway bar with adjustable drop links. 2.0 4 cylinder car. brant |
Gerard asked about ride heights. I'm sorry I don't actually have those numbers with me, and I'm not even sure that I kept them after my last corner balance job. (As a side note I was able to get my corner balance within 5lbs total, with driver).
The ride heights that you use should be dependant upon hardware and not set in stone. Here are a couple of my observations: - slight downward rake towards the front of the car. - too low is not even good on the track. My car is a track only car and I don't worry about dips as much as I do about track edges now. - There needs to be both suspension travel and air flowing under the car. - Of course the lower the center of gravity is the better to a point. - Pay attention to the angle on the steering rods and set your front ride height so as not too compromise this. I'm using 225/50 tires all around and of course your tire selection is going to have an impact upon the ride height numbers as well. Long story short..... I didn't answer your question Gerard. I choose to go very low as my car is only on the track. I would recommend that you set your front ride height enough to clear a parking curb and then put the rear at a slight upward rake. With the adjustable rear collars it is infinitely adjustable. You can always index your front torsion bars as well. I'm guessing that my front suspension bolts have 5 or 6 inches of clearance but this is on an aluminum front cross frame and may not directly correlate to a steel front cross frame measurement. I don't set my heights to a certain measurement, but rather, I set them to my needs and then make sure they are equal. Hope this is of some assistance. brant |
I am curious. what is all that information for stock specks?
------------------ Sweet Blue 72' 914 Check it out at http://www.geocities.com/eat_um_up/914.html |
OK, here's some more detail.
Brant, the reason I was after specific measurements is to give others an idea what setup they could use to get a specific height (or range of heights). As you mentioned, your rear collars allow setup to be infinitely adjustable - and this would be an important factor for the data I'm compiling. If you'd be willing to provide at least your current heights (measured as indicated), then I can relate that to your setup. Eat-um-up, I would like to know that as well. The stock parts would be no problem, but finding the stock heights might be more of a challenge. All I know is that mine are way too high - just over 7in (from ground to circular jack pad) in rear, and 5in in front. The rear tires barely sit inside the wheel well (1/2 in overlap, maybe). I just figured all this effort I go thru shouldn't have to be redone by others - especially if I can gain input from those who have already done it. Thanks, ------------------ Gerard 74-914 2.0L 3D914 rodrigos6@juno.com |
My current setup:
Rear shocks: Bilstein Rear springs: Weltmeister 140lb (not cut), regular "slot-type" (not threaded) perches Tire size: 205/50-15 Wheel size: 15x5.5 Fuchs street, 15x6 Panasport track Swaybar: factory Heights: 22 1/2" front, 21 3/4" rear Rear alignment: -2 degs camber, 3/32" toe-in (I have the corner weights etc. if that helps.) Next month I will be going to 180lb rear springs and 22mm tubular front torsion bars. I am undecided on the swaybars but will either go to a 22 up front and keep the rear, or keep the 19 up front and remove the rear. Cheers, ------------------ Chris C. 73 914 2.0 70 911E Targa campbell.chris@gte.net [This message has been edited by campbellcj (edited 10-09-2001).] |
75 2.0L with A/C
21mm torsion bars turbo tie rod ends ATS 15x5.5 195/50/15 Yoko's Bilsteins all around, rears on middle setting 165 lbs. progressive springs. Front A-arms are parallel to ground. Stock front sway bar Cars in the paint shop (still!!!) I rolled the rear fenders and will try 205/55 or 205/60's next. |
Here is a couple of pictures of my car with various tire setups.
New Track Tires: 225x15x50 Komo Victor Racers <IMG SRC=http://www.members.aol.com/paddlerjim/914dial.jpg> |
| All times are GMT -8. The time now is 02:56 PM. |
