Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
Type IV torgue values
I am fixing all the vacuum leaks that have developed over in the intake for my (new to me) 912E's L-Jetronic FI......
I don't have a 914 or Type IV manual so I'm not sure how much to torgue the manifold/head studs now that I'm putting it all back together...(new sleeves, lg & sm inj. seals, int. manf. gaskets, epoxy small crack in the plenum box, clean up the throttle body, repaint intakes, new fuel & vacuum lines,etc.etc.) Can someone help me ??? I'm guessing 15 lb.s, but I really don't want to guess.... THANKS GREG
Greg....PCA, 356 Registry, 912 Registry 1977 911S Targa with 3.2...1960 T-5 coupe 1968 912 coupe, that's 32 P-cars, so far... 1990 Chevy 4x4 2500 pickup (with 255K & still rockin') |
I checked Haynes' and Hussey's 700 Tech Tips and can't find anything for the manifold studs.
Lotsa luck...I replaced everything you replaced and still seem to have a vacuum leak.
1974 914 2.0 1980 911 SC 2002 996 Cabrio 2000 Silverado 2011 Golf |
Standard 8mm torque, 13-15#. I use 13 on questionable fasteners and 15 when I know that everything's perfect.
I found this- http://www.dansmc.com/torque_chart.htm And this- http://www.pelicanparts.com/914/technical_specs/914_torques.htm |
Here is a link to the 912E FI manual on my website, which may be of help to you:
http://members.rennlist.com/914_collectibles/zRareDoc14.pdf |
914 Geek
The manifold nuts are M6, not M8. I'd go with 10 lb-ft.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
![]() The studs that hold the manifolds to the head are 8x.125. 15ft/lbs is the proper torque spec for them....
Clay Perrine 74 914 1.8L (Frodrick) 73 914 /6 4.0L 964 motor (Igor) 70 914 /6 Factory Six. (Elwood) 95 BMW 540i (Inga) |
914 Geek
Oh, heck!! I was thinking of the nuts that hold the injectors in--D'OH! Yes, the manifold nuts are M8.
Say hi to Betty for me, Clay! --DD
WE can always rely on the 914 fixit gru. Come to think of it, Clay does look like Mike Myers.
