MarKoBrow's Avatar
914 Trans Magnesium or Aluminum???
I am trying to find out if the 914 transmission I have is made of Magnesium or Aluminum. I have to have my nose cone welded, if it aluminum I can welded or all the welding shops in my area can weld it if is the other not so easy.
1997 911 Carrera Cabriolet
66 912, 67 912 Outlaw
65 Ac Cobra reproduction
2012 Audi A8L
1999 Ferrari 360 Modena
Old 07-27-2008, 11:27 AM
MarKoBrow's Avatar
I should have added that is a side shifter trans and I am not sure of the model year but I think 74 was the year of the car
2012 Audi A8L
Old 07-27-2008, 11:29 AM
BURN-BROS's Avatar
Magnesium
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 07-27-2008, 12:37 PM
MarKoBrow's Avatar
Thank you for your answer, Was there ever an aluminum case for the 901 transmission? I am just curious
2012 Audi A8L
Old 07-27-2008, 03:15 PM
gearhead
There was an aluminum case for the 901 in the 1965-1969 911's. Partway through 1969 the 911 transmission was released and it was magnesium, as is the 914 transmission that was released conccurently with it. People often call the whole family of transmissions the 901 family but there are 3 distinct members to it, with there being both the side shift and the tail shift ones within the 914 grouping. You cannot take a 901 bellhousing from a 911 and put it into your 914. The middle section on the aluminum cases are different as are some other things. But the flipside is that your mag case is lighter.
I've got a sideshifter tailcone available if you are looking for one. PM me if you are interested in it...
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-27-2008, 04:38 PM
