Post Carbs
Just wondering if anyone has ever tried to run two Webber 2bbl progressives?
I am using a 2bbl progressive and have a spare. I wonder if it would work. With the carb I have, it seems somewhat breathless at medium RPM.
Sanity check: My motor turns 3000 rpm at 70 mph. Sound right? ~3300 at 80.
Karl
Old 10-29-2001, 09:08 AM
mejulihn's Avatar
Post
I just checked my '76 with 185-15 tires using a handheld GPS unit and your speeds sound about right.
Old 10-29-2001, 10:09 AM
Post
Thanks for the speed check. I thought it seemed reasonable.
I still have the question out as to whether anyone has tried to run dual 2bbl progressives.
Karl
Old 10-29-2001, 01:31 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
You could biuld a manjfold for each side or use two of the "normal progesive manifolds on shortend runners, but it will not run very well unless you spend alot of time tunjng and even then I think you will have driveabilty problems. Steve
Old 10-29-2001, 02:06 PM
