Post gas tank lines
I changed the short lines beneath the gas tank. I made them to long and they kink when I set the tank in. Is there an easy way to make them shorter? It was hard to tighten the clamps the first time.
Old 11-04-2001, 06:52 PM
Jim Smolka's Avatar
Post
I assume you took the tank out to replace the lines. You might able to use the hoses as is, just route them a little differently as you place the tank into possition.
Old 11-05-2001, 02:30 PM
